Weathering with oils
Posted by Anonymous on Tuesday, June 15, 2004 2:44 PM
I'm reading an old FSM article (don't tell my boss) on weathering with artists' oil paints, and it recommends covering the model with a clear flat lacquer like Testors Dullcote before weathering, to protect the base coat from the oil paints.
My question is, would Future work here, or should I spring for the expensive stuff?
M.
Posted by Anonymous on Tuesday, June 15, 2004 2:57 PM
By weathering you mean painting the panel lines or dry brushing streaks?
If youll be doing panel lines you'll need a really smooth surface like Future. But if you're going to dry brush it i think a flat surface is best.
Posted by Anonymous on Tuesday, June 15, 2004 3:25 PM
Well, it's a tank, not an airplane, so neither. Smile [:)]
I want to do three things:
1. Create a faded paint effect by painting upper surfaces with a lighter shade of the base colour
2. A wash
3. Drybrushing to bring out raised surfaces
The FSM article talks about how to do all three; I just wonder if I can substitute Future for the Dullcote.
M.
Posted by Anonymous on Tuesday, June 15, 2004 4:02 PM
Hi MarianLH,
The only thing about substituting Futurt for Dullcot is that the Future is shiny . If you use it you will eventually haver to add something to remove the shine. Future is a great coater to work over but it does have its drawbacks (shine). I am sure someone with a lot more smarts than I will have your answer.
Richard
Posted by Anonymous on Tuesday, June 15, 2004 4:28 PM
Woot! Never mind! I found the answer in Matt Swan's "The Complete Future":
"Because Future is a true Acrylic coating washes that are oil or Turpenal based will not affect it as they would lacquer or enamel based coatings."
Off to the store!
M.
Posted by Anonymous on Tuesday, June 15, 2004 6:00 PM
woot?
