In the MM modeler's technical guide it says:
" When clear coating over metallics, i.e., chrome, silver, copper, aluminum, DO NOT USE CLEAR TOP COAT ENAMEL! The enamel will deleaf or dull the metallics. Instead use Glosscote or Dullcote Lacquer! You can also use clear acrylics #50160 or #50161, as these will not dimish the reflectance of the metallics."
Now im sure you could use another brand of acrylic but the info is pretty to the point. As for alclad I agree there is no better finish than just buffing and leaving it natural. I hope this helps.
