What is the best I can expect from this brush. I am trying to paint a 1/35, WW2 German Kubelwagon, overall dunkelgelb (went on OK), then randomly sprayed with a dark green graffiti looking pattern in thin wavy lines (at this scale about 3mm wide)
I have tried different thinning and pressures with no success. The main problem is a paint spatter at each side of the line I am trying to paint. I have repainted the model in dark yellow before I try again.
I can achieve a thin line on test samples of scrap styrene but when I hit the subject the brush takes on a life of it`s own as I try to follow the contours of the model.
Is there a set ratio of paint/ thinner/ pressure that i should be aiming for, or is it just trial and error and practise until I find out.
This model is now on hold until I learn how to do it correctly.
Thanks for listening
Daveash
