Tamiya thinner
Tamiya thinner
Posted by Anonymous on Monday, July 5, 2004 2:08 PM
Do you know what is the best alternative thinner for Tamiya Acrylics other than the Tamiya thinner?
Thanks
Saul
Posted by Anonymous on Monday, July 5, 2004 2:24 PM
iso alcohol, 99%
    January 2004
Posted by MusicCity on Monday, July 5, 2004 2:30 PM
QUOTE: iso alcohol, 99%
Not always ... it causes the finish to turn out flat. 91% isopropyl alky (not 99%) is what I normally use, but I normally want a flat finish. If you want gloss Tamiya's thinner is your best bet, but if you want flat you can use alky with no problems. 50% alcohol and 50% water might prevent the finish from being flat but I haven't tried it.
Posted by MikeV on Monday, July 5, 2004 2:34 PM
Scott,
Do you notice any difference in the 91% Iso and the 70% Iso alcohol mixed 50/50 with water?
I am not sure which one I have but I believe it is the weaker 70% if I remember correctly.
    January 2004
Posted by MusicCity on Monday, July 5, 2004 2:49 PM
I only used the alky / water mix once with MM acrylics, and the finish was about the same as I got with just 91% alky. The tip-dry problem wasn't as pronounced though and it dried a little slower.
Posted by Anonymous on Monday, July 5, 2004 3:03 PM
but don't use water with tamiya paints
Posted by Anonymous on Monday, July 5, 2004 3:46 PM
Have you experienced any crackling problem with thinners others than Tamiya's?? That's muybiggest fear using a different thinner??
Saul
    January 2004
Posted by MusicCity on Monday, July 5, 2004 3:52 PM
QUOTE: Have you experienced any crackling problem with thinners others than Tamiya's?? That's muybiggest fear using a different thinner??
No, I haven't had any cracking problems at all. Probably 90% of what I paint is airbrushed using Tamiya acrylics thinned with 91% isopropyl alcohol and a couple of drops of retarder. The retarder slows down the drying time so I don't have such a problem with dry tip on my airbrush. It sprays fine, goes on smooth, and the only down side I've noticed is that the surface is always flat.
