- Member since
Posted by Anonymous
on Wednesday, July 7, 2004 3:13 PM
does the Badger 100LG paint as fine a line as the Iwata HP-C?? How fine a line does the Omni 4000 paint in comparison to these?
Iquote]
the lg is compared to the hp-b, which is even finer than the hp-c
the omni is kinda closer to the hp-c
with proper needles and nozzles, the 150 should do in your case, if you need good fine lines, get a 100LG or a hp-c because the hp-b's nozzle is not meant for modeling paints.
Posted by blabride
on Wednesday, July 7, 2004 6:41 PM
Thanks for your answer. That is good to know about the HP-b. How similar is the 100lg's tip to the fine tip on the 150? On the internet they look like they might be the same piece. Also how does the tips size on the Omni 4000 and Badger 100lg correspond to the decimal number sizes given for Iwata's tips?Or do they ? Sorry for the detailed questions but the answers seem to be here. This is easily the best hobby forum I have found.Thanks
- Member since
July 2003
Posted by saltydog
on Wednesday, July 7, 2004 9:33 PM
blabride, you should consider the iwata eclipse hp-cs friend. it has a .35mm needle/nozzle combo and is capable of very fine lines. i also have the hp-c with the .3mm n/n combo that you can achieve fine lines with but it is very finicky when using modelling paints as i personally think the .3mm nozzle is too small to shoot model paints effectively. there are some on here that use the hp-c with no problems though. i also have an omni 5000 which is like the 4000 except with a smaller color cup. i can achieve the fine line with any of the three. out of the three, i'd say the hp-cs is the best all around airbrush that i've ever used. i also have the iwata hp-c. now, its a long story and i'm not gonna tell it, but i have the .4mm n/n conversion for my hp-c and i absolutely love this little set up. the comfort of the hp-c is excellent in my big hands. when doing cammo or really fine weathering and such, i slide the .3mm needle into the .4mm nozzle and this little set up rocks when it comes to the fine line!!! it cost me like the dickens to arrive at this set up, but i'm so glad that i have it. the fine line is effortless with the right paint to thinner ratio and psi!! its what i use for all detail work that i do.
but remember, the airbrush and taper of the needle and all that is important, but the viscosity of the paint, psi, and the distance from the surface is key when trying for the fine line. hope this helps. later.
Chris
The Origins of Murphy's Law:
"In the begginning there was nothing, and it exploded."!!!
_________
chris
- Member since
Posted by MikeV
on Wednesday, July 7, 2004 9:50 PM
I would agree pretty much with what has been said so far.
The Badger 100LG with a fine tip is equal to the Iwata HP-B but neither are really reliable for modeling paints with the fine tip.
I have the 100LG and it has a medium tip and needle as that is how it was sent to me at Badger's recommendation for modeling.
I am an online Badger rep of sorts so I have many of their airbrushes to work with for comparison purposes. The best airbrush that Badger makes for the finest lines would be the Sotar 2020, although I don't know if you would need one or not. Here again I would use the Sotar with the medium tip as the fine tip is too finicky with modeling paints and was designed for inks, etc.
Your Badger 150 with a fine needle/tip combo should spray about as fine of a line as you would need, but being that it is a siphon-feed model the air pressure needs to be higher than a gravity-feed which causes you to lose the ability to spray fine lines with less overspray and control.
In order from finest lines to less precise airbrushes I would go with the Sotar 2020 at the top followed by the Badger 100LG, then maybe the Omni 4000/5000.
I hope this helped somewhat.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
- Member since
Posted by Anonymous
on Wednesday, July 7, 2004 11:15 PM
BADGER!! I cant wait to use mine...2 more days.
- Member since
July 2003
Posted by saltydog
on Wednesday, July 7, 2004 11:36 PM
jeff, you kill me!! never even laid a hand on the airbrush but recommending it left and right!! keep it up, you funny. later.
Chris
_________
chris
- Member since
Posted by Anonymous
on Thursday, July 8, 2004 3:32 AM
It just feels right in my hand. BTW have you seen my post for you in the plane section??? It's like on the 3rd or 4th page now...named for Saltydog. Its about stangs and youll like it
- Member since
July 2003
Posted by saltydog
on Thursday, July 8, 2004 7:43 AM
yes i did jeff, and i appreciate it friend. i meant to go back and post a big thank you, but i let it slip to the dreaded 2nd page and forgot about it. sorry, but my belated thank you is deserved. later.
Chris
_________
chris
Posted by blabride
on Thursday, July 8, 2004 7:57 AM
Thanks guys this helps a lot. Being that I have a lot of badger's stuff already I may try the 100lg. But the Iwata may get a try as well. My son will be headed off for college in a year or so he could always use an airbrush right. Sounds like a good excuse to buy both.
- Member since
July 2003
Posted by saltydog
on Thursday, July 8, 2004 3:51 PM
i bet you'll be keeping the iwata hp-cs and sending the badger packing with the son if you do!!! later.
Chris
_________
chris
- Member since
Posted by Anonymous
on Saturday, July 10, 2004 5:55 PM
i think he'll send the badger to mikeV
- Member since
Posted by MikeV
on Saturday, July 10, 2004 6:24 PM
At least one of us appreciates a quality airbrush.
- Member since
July 2003
Posted by saltydog
on Saturday, July 10, 2004 8:32 PM
i don't get it!!
Chris
_________
chris
- Member since
November 2003
Posted by roosterfish
on Sunday, July 11, 2004 12:31 AM
QUOTE: Originally posted by blabride
Thanks guys this helps a lot. Being that I have a lot of badger's stuff already I may try the 100lg. But the Iwata may get a try as well. |
If you already have a lot of Badger equipment I would recommend you stick with using a Badger or Thayer & Chandler AB. Iwata and Badger use different air hook up on the AB and the air hose. It is not that expensive for the hose and hook ups but you will have to have the hassle of duplicating equipment.
Winners never quit; quitters never win.
- Member since
Posted by Anonymous
on Sunday, July 11, 2004 8:09 AM
Bet the Iwata gets the college degree.
- Member since
Posted by Anonymous
on Sunday, July 11, 2004 5:31 PM
More great sites from Kalmbach Media
