QUOTE:
It sounds like though I found do the figures and small pieces with just the paint. Is that right?
You can do it, but I think once you try some acrylic on something you'll see what I mean about it drying so fast. The retarder makes a world of difference, and even though I don't brush paint very much, I just wouldn't even attempt to do much without slowing the drying time down.
The advice everyone gave about using rattle cans for the bulk of your painting is very good advice. However most of the spray can paint is enamel. If you spray it over acrylic, make sure the acrylic has had at least 24 hours to cure or the enamel may cause it to lift or dissolve. Ditto for masking acrylics. Make certain it is thoroughly cured and even then I recommend using low-tack masking tape.
One other word of advice: Always, always, always clean your parts before painting with acrylic. Most people wash them in soapy water and let them dry overnight. I use alcohol because I'm too impatient to wait for them to dry. Acrylics are water based and don't have any solvent-type thinners in them. Any grease or oil left from the molding process will not get dissolved by the paint and can keep it from adhering to the plastic.
