QUOTE:
Have you tried the 3M fine line blue tape?
I hear it is good but I have never tried it.
Mike, I use a lot of 3M Blue masking tape, but whether it is "Fine Line" or not I'm not sure. It's low-tack for delicate surfaces (not "Super Low Tack" for "Super Delicate Surfaces", that stuff is like Postit pads!). I like it a lot and for areas that I haven't painted or just need general coverage, that is my preference. For areas I've painted I usually opt for the Tamiya because I don't like to take chances. I haven't had any serious paint pull up problems and I'd like to keep it that way
This is the kind I'm using:
http://products3.3m.com/catalog/us/en001/home_leisure/-/node_PQLG3ZLPQLbe/root_GST1T4S9TCgv/vroot_GSHCV1ZFXKge/gvel_HJZKR0VRGDgl/theme_us_homeleisure_3_0/command_AbcPageHandler/output_html
(I hate those long links, but blame it on 3M)
Juniormodeler, IMO Tamiya is the way to go. I mainly use acrylics and I always worry about paint getting lifted. Like I said, it doesn't happen much but I'm pretty picky about what tape I use. The Tamiya tape is very, very thin, semi-low tack, and as long as you burnish the edges well I've never had it bleed.
