bubbling paint on my B-26 marauder
Posted by Anonymous on Monday, July 26, 2004 6:36 PM
I just got paint an started painting my B-26 and ran into a problem.I using the testors spray paint and painted and let it dry.after a few hours I wet to check on it and sighted that the paint was bubbling.I put another coat on it and that did not help.so can anybody have any solutions?thanks-bradBig Smile [:D]
Posted by dubix88 on Monday, July 26, 2004 8:45 PM
HEY,
I dont have any solutions but i do know why this happens(at least i think i o) It is because you applied the paint too quick and in one heavy coat. This traps air in the paint and causes bubbles to form and pop on the surface. Guys please tell me if im right or wrong. To stop this, when you are painting, do it in light caots. I use to have the same problem with my cars and i dont no more so that must be the way to stop it.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by rjkplasticmod on Monday, July 26, 2004 9:11 PM
The bubbling, or blistering, is usually a sign of a chemical reaction. What type of paint were you spraying, enamel, lacquer, or acrylic? Did you prime the model before painting? If you primed, did you let the prime coat cure for at least 24 hours? If you provide a little more detailed info, might make the analysis easier.
Regards, Rick
Posted by MikeV on Monday, July 26, 2004 9:32 PM
Regards, Rick
Sign - Ditto [#ditto]
I agree with Rick.
What is underneath that paint?
Posted by Anonymous on Monday, July 26, 2004 9:59 PM
thanks for the replys! I am using a primer and then I am going to paint the coat on.I am painting on bear plastic.any tips are great thanks agian!-brad
