How do you clean an Aztec 4709?
Posted by RonUSMC on Monday, April 21, 2003 10:31 PM
Dont waste too much of your time. I have one on the way and was just curious. Is it easier to clean than a Paasche VL? God I hope so.
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
Posted by naplak on Monday, April 21, 2003 11:33 PM
I had one of the Azteks... and here's what I did.
After finishing painting... spray thinner or cleaner thru it till it flows clear.
Take out the nozzle and drop it in a bottle of cleaner.
Use a pipe cleaner to clean our the air-brush body. If you have more painting to do, put the nozzle back in and blow air thru it to flush it out... OR put in another nozzle to use.
Clean the nozzle by dribbling cleaner thru it while brushing it with an old tooth brush.
Let everything dry.
I did not take the nozzles apart very often -- every 5 - 10 uses.
I used Mineral Spirits for enamel paint, Acryl Cleaner for acrylics, and Lacquer Thinner for lacquer paints.
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
Posted by RonUSMC on Tuesday, April 22, 2003 7:51 AM
hmmm. It might be easier then I think.
