Frisket Paper Masks
Frisket Paper Masks
Posted by genj53john on Thursday, August 5, 2004 8:02 PM
Ran into a problem when I used fisket paper to mask of a camouflage pattern on my 87B-2 Stuka model. I began by painting the light under coat which sat for nearly a week before I used the frisket paper. It should have been fully cured by then. After I masked off the pattern and painted the darker color I removed the frisket paper which in turn removed some of the paint underneath it. Now I need to start all over. Any suggestions on how to prevent this? Should I now remove all paint before starting over or just repaint on top? What’s a good way to remove the paint? By the way I used Model Master Acrylics.Sad [:(]
John
    January 2004
Posted by MusicCity on Thursday, August 5, 2004 8:14 PM
That's the primary reason that I prime sensitive sections like that. Model Master Acryl is good paint, but acrylics just don't adhere that well. I'm going to be doing a lot of masking or handling I want the paint stuck. A thin coat of primer will go a long way in preventing that from happening. I don't paint much with enamel, but I like Tamiya Fine Surface Primer in rattle cans. I just take it outside to prime it.
Also, make absolutely certain there is no grease on the surface before painting. This is especially critical with most acrylics. You can wash the parts in soapy water, rinse, and let them dry thoroughly. I prefer to use alcohol since it dries much quicker than water. Water can hide in cracks for a long time.
My guess is that to remove the paint all you need to do is pick it up with masking tape. It doesn't sound like it stuck very well. Castrol Super Clean is the way to remove paint; acrylic or enamel. It will dissolve it in just a few minutes.
Painful as it may be, I'd try pulling on the bottom with some masking tape. If it sticks everything is probably OK. If it starts to peel I'd just strip it all off and repaint the whole thing. Sorry for your problems, wish I had a quick fix.
Posted by Anonymous on Saturday, August 7, 2004 7:15 PM
I second all the above plus I add you should lightly sand your model before washing it. Use the finest grade paper you have for the job and use a light touch and sand the entire model. After you wash it and let it dry, a clean and sanded model will hold most paints very well, they have a little more to bite into that way.
Posted by mass tactical on Sunday, August 8, 2004 7:20 AM
Sign - Ditto [#ditto] the above comments. I have had success airbrushing a light coat of Future over the base color and letting it cure for at least 48 hours before masking. I also will press the masking material against glass or some other clean smooth surface to further remove some of the tac before placing it on the painted surface. If doing a multi color camo pattern, I will Future each coat before moving on to the next color. Hope this helps.Big Smile [:D]
Mike M
