Air pressure adjustment from compressor ?
Posted by Anonymous on Friday, August 6, 2004 3:43 AM
sorry for my silly question but... Blush [:I]
how do you adjust the air regulator ? When the air flows, or when the air is closed ?
thx ! Tongue [:P]
Posted by Anonymous on Friday, August 6, 2004 4:43 AM
I usually adjust mine when the air is flowing.
I tried to do it when it wasn't and a couple times it stopped flowing on me.
So it not a silly question. The only silly question is the one not asked
    January 2004
Posted by MusicCity on Friday, August 6, 2004 5:13 AM
Nope, not a silly question at all.
People do it both ways. It doesn't really matter since it's just a reference, what matters is that you do it the same way each time. Static pressure will be a little higher than when air is flowing so I usually adjust mine when air is flowing..
    July 2003
Posted by saltydog on Friday, August 6, 2004 10:01 AM
like scott says, its really up to you, i do it when the air is flowing because the needle on my regulator indicates about a 5 pound drop when i start the flow. thats my regulator though, other ones may not do that. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    December 2003
Posted by 9x19mm on Saturday, August 7, 2004 12:42 AM
Mine has any where from 5 to 10 psi drop so Ill set it air off at first then fine tune with it flowing.
