My perfect compre$$or
Posted by Anonymous on Sunday, August 8, 2004 6:12 AM
The $$ are intented for saving them .... Big Smile [:D]
that's my self made silent compressor (DIY), it costed me approx $100 but it's VERY silent, imagine to have a refrigerator near you..., it's capable of 40psi (costants) and has a tank of 6 liters, considering that here in Italy if you want to buy a silent (hey.. really silent..!) compressor the minimum it's about $250/300....
and on top of it, just leaned, the brand new Omni 4000..Cool [8D]
and... before someone ask me.., I have to replace the stupid vinil hose ... with a braided one...
Tongue [:P]
    January 2004
Posted by MusicCity on Sunday, August 8, 2004 6:20 AM
Looks good to me. All that matters is that it blows air and does it quietly. How much that costs is up to the individual, and you found a good way of doing it.
Personally, I like the vinyl hoses. I have both and the braided hose is not as flexible and really gets in my way so I normally use my little vinyl hose.
    August 2004
Posted by jdavidb on Sunday, August 8, 2004 9:52 AM
Does the red tank have a way to drain it? If not, it could rust from the inside, which would be dangerous.
Where is the compression unit? Is it inside the black pots? Do you have two mini compressors running it?
    May 2003
Posted by qmiester on Sunday, August 8, 2004 10:15 AM
Refridgerator compressors huh? I haven't seen one of those used outside a fridge in years. 50 years ago it wasn't uncommon to find a rig much like yours in a home workshop or garage. The only question I have is does it "walk" when it's working? That is, does the operational vibrations from the compressors make the stand move?
You did a great job.
Quincy
Posted by Anonymous on Sunday, August 8, 2004 11:42 AM
I built my own silent compressor a few months ago and it works great. I have a four gallon tank and all the features as the $600 dollar ones. Good job on yours it looks good and I hope it provides you with a good service life. That's a good airbrush you have and other than wanting one your vinyl hose is fine.
John
Posted by MikeV on Sunday, August 8, 2004 12:23 PM
Charger2000,
You did an excellent job building that setup. It looks really good and should last you a long time. Thumbs Up [tup]
I am sure it fills that tank fast too with dual compressors feeding it. Wink [;)]
One other thing that I would do is add a couple fans shooting air at the heads of the compressor motors to keep them cool as heat is what kills compressors. I put a 120mm computer fan at the back of my Badger Million-Air compressor to help cool it.
Posted by Anonymous on Sunday, August 8, 2004 2:23 PM
nope, there isn't an appropriate way to drain it, every 3/4 month I'll open the lower tap and simply tilt the whole thing
yep, refrigerator units...
No, absolutely stady, there are anti-vibration pad between the wood and the fridge unit
I never do long sessions, after one hour of start&stop the unit get not that hot...
thanks to everyone for feedback, and for suggestions about the Omni 4000 Shy [8)]
Approve [^]
Posted by Anonymous on Sunday, August 8, 2004 9:07 PM
Mike or someone else, Is there a way you can attach something like a small hole on the bottom of a tank, and put some pressure-sealed "cup" there, and a drain valve so when you're not using the compressor, you can drain it?
Posted by MikeV on Sunday, August 8, 2004 9:15 PM
Ryan,
It is tricky trying to do that as you would need a good welder to build a draincock that would work without being dangerous.
I would recommend you buy a tank already built with a drain opening such as these ones for 4x4 trucks.
http://www.kmwperformance.com/prod.aspx?c=6
Posted by Anonymous on Monday, August 9, 2004 1:49 AM
Ryan,
was not a good idea to drill the tank, the iron was to thick, and I wasn't sure how to make a good sealing...
Nik
Posted by Anonymous on Monday, August 9, 2004 10:35 AM
Thanks mike
I think i'll just go with a normal tank, 1 hole on the very tip of a tapered endcap, and a really good seal, powered by a fridge comp
