QUOTE: Does Tamiya Fine Surface Enamel Primer work okay for appling acrylics over them? I heard once then acrylic is okay over enamel but not enamel over acrylic and oil based okay over both. at least that is what I heard. |
Yes, it works just fine. Most of what I spray is acrylic and I use the Tamiya primer a lot. As long as the enamel primer is fully cured you can spray acrylic over it with no problems at all. Actually, as long as the base coat is thoroughly cured you can spray anything over anything if you are careful. I've sprayed enamel over acrylic and it worked fine, but I gave the acrylic several days to thoroughly cure.
Laquer is the tough one, and many of the gloss and dull coats are actually laquer. If you spray laquer over acrylic (or to a lesser degree over enamel) you have to be very careful. The first couple of coats need to be no more than a mist or they can affect the acrylic underneath.
QUOTE: When I used the Testors MM Primer as a flaw catcher I am not so concerned with tis milky (did I mention that it is a white milky look) sustance look. It is just strange that I mix for so long and it is still there. My concern is when I used it for the metal figures I am putting together. I just don't want the paint to fall off.
I can understand that. The color of primer is not as important to me either. I use either white or gray, whichever the LHS has unless I'm painting yellow (I HATE yellow!).
Check the primer you are using and see if it is made for plastic and metal. Some styrene primers don't adhere to metal worth a hoot. For metal figures I'd think your best bet would be some sort of automotive primer since it is designed to stick to metal.
