Plus, I wouldn't be trying for 1-shot coverage if you use the thinner plus an Eclipse. Spray a part, give it a few seconds while you spray other stuff, then go back & give it the covering coat.
During painting, lightly swabbing the tip/needle of the Eclipse with a q-tip (soaked with the thinner) will dissolve nozzle clogs. Be careful not to put pressure on that needle with the q-tip though. Let the liquid do the work.
