i will second all that Musiccity has said.
initially, i spray the lightest color first at a standard thinning ratio of about 50/50. i prefer my paint to be thin, then just build up the coats until i'm satisfied, i get a nice smooth finishe everytime using this method. then, i swap to the next darkest color and follow the lightly marked out pattern on the surface of the subject. i mark it out with a pencil in a dotted line fashion. at this point, i'm not even worried about tight demarcation lines yet, just get the colors on the subject. progress to the next dark color and so forth and so on. when i'm happy with the coverage of all three or ever how many colors you got in the camo pattern, then i thin the said colors down further to about 60%thinner to 40%paint, drop my pressure well below 10psi as scott has mentioned, and start the long, arduous task of tightening up the demarcation lines. this will require skill, patience and a steady hand. i'm into each color 3 and 4 different times usually correcting slip ups and such until i get the shceme to look like i want it to. i use an iwata eclipse hp-cs most of the time, and this is a gravity feed. do not use lacquer thinner for your thinning agent, you'll never get a nice thin line using this stuff, it drys too quickly, i prefer turpentine myself, but mineral spirits will work ok.
here is an example of the end result of the method i just explained:
