Problems with spray can painting
Posted by Anonymous on Sunday, August 15, 2004 10:57 PM
A while back, I spray can painted the body of a 1960 Ford Starliner gloss black (I did not prime the model- only applied the gloss finish coat). After the paint dried, little specs of dust appeared to be embedded underneath the paint. I sanded those specs down, but after applying a second coat of gloss black, the paint job looked even worse than before. I tried a third coat, but still the same result. Eventually, I stripped all the paint off the model and now I am going to start over. I was just wondering what I could do to successfully paint this model with a spray can.
    March 2004
Posted by bstrump on Sunday, August 15, 2004 11:26 PM
I remember having this problem as well. Although hobby paint is designed to be sprayed directly onto plastic, I've never been successful at it. Bare plastic does seem to attract a lot of dust but I think there's more than a dust problem going on here.
First of all you should get into the habit of priming. This lays a good foundation for the color coats. Then mist on the first two or three color coats before applying the wet coats as this will provide a good tooth. Also, before spraying, warm up the spray can in hot (not boiling) water first. This will help it to flow better.
Finally, try to dig up some articles on spray can painting by Pat Covert. He's the master at it and he did a lot of writing for ScaleAuto. I think he wrote a book as well.
Posted by dubix88 on Monday, August 16, 2004 5:47 AM
HEY,
Also you should wash the model in a mild detergent before painting, that way any pelease agent used to get the plastic out of the mold duuring manufacturing hets cleaned off. And ya, you should get use to priming, it only take about 2-3 coats, and it dries pretty quick.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
    January 2004
Posted by MusicCity on Monday, August 16, 2004 7:09 AM
If it truly is dust it is probably settling on the model while the paint is drying. You can eliminate a lot of that by putting the model under a box whie it is drying. For something like your Ford I'd use a shoebox. Cut big holes in the ends and top (the top is actually the bottom since you'll flip it over when you put it over the model), and cover them with coffee filters. That will let air circulate but keep the crud from settling on it. Be sure and blow the box out before you put it over the model.
FWIW, when drying smaller parts I just put one of the cone-shaped coffee filters over them while they dry. Same thing, the air can circulate dut the dust is kept out.
Posted by dubix88 on Monday, August 16, 2004 10:09 AM
HEY,
That is a great idea scott. I usually just use the box the model came in bacause you know ittl fit if your building a car. But i have never cut holes in the top and put cofee filters on it.
Randy
    January 2004
Posted by MusicCity on Monday, August 16, 2004 10:36 AM
QUOTE: I usually just use the box the model came in bacause you know ittl fit if your building a car.
Good point and a good idea. The stuff I build usually outgrows the original box pretty quickly so I didn't think of that. Whatever you use, just keep it around with the coffee filters on it and then use it whenever you need it.
Posted by Anonymous on Monday, August 16, 2004 11:59 AM
Good tip Scott!! I'll be trying it out!!
Murray
Posted by dubix88 on Monday, August 16, 2004 8:18 PM
HEY,
Meeeeeeeeeee 2
Randy
