Specifically what problems are you having with it? Is the air not getting to the airbrush or what? A compressor doesn't really care what kind of airbrush is hooked to it, it only blow air. You may have to get an adapter of some sort to adapt the airbrush connections to the compressor, but that should be the only problem.
As to what specifically works with that compressor, I suspect it's the Aztek line since that's what Testors sells. Personally I'd rather have any Paasche airbrush than any Aztek airbrush.
