acrylic paint primers
    September 2003
Posted by out04 on Wednesday, August 18, 2004 7:47 PM
This has probably ben up here before, but what can be done to prevent drafting tape from pulling up acrylic paint?
    March 2004
Posted by bstrump on Wednesday, August 18, 2004 8:23 PM
Before you paint, you needto thoroughly wash your model in amild detergent solution to get rid of mould release agents, sanding crud and oils from your hand. Then lay down a good quality primer. This provides a tooth for the color coats. Also, you should use a premium quality masking tape that has low tack. You said you use drafting tape and this should be fine. Masking tape is one of those things where you get what you pay for.
    January 2004
Posted by MusicCity on Wednesday, August 18, 2004 9:11 PM
Acrylics are bad about that, but BStrump's advice is right on the mark.
I've used drafting tape for masking, but have also had problems doing that. Drafting tape is designed to release from paper without tearing so it is very low-tack, but the adhesive was never designed to resist paint solvents and is sensitive to some paints. I've had it bleed very badly because the paint solvents dissolved the adhesive (although that was with a brush and not an airbrush). It doesn't happen often, but once is enough.
Posted by darson on Wednesday, August 18, 2004 9:14 PM
Sign - Ditto [#ditto]Sign - Ditto [#ditto]
For masking tape I use Tamiya tape exclusively, IMHO it's the best around.
Darren
Posted by Anonymous on Thursday, August 19, 2004 10:36 AM
I'll echo the advice to use a good primer and good tape. Tamiya's been mentioned here, but also check out fine line striping tape from an automotive paint supply shop. They come in all sorts of variants, some high tack, some low tack. Low tack is better if you're struggling with paint lift problems.
    September 2003
Posted by out04 on Thursday, August 19, 2004 7:49 PM
Should I use acrylic or enamel primer?
Posted by MikeV on Thursday, August 19, 2004 7:52 PM
Enamel primer is better as it chemically bonds to the plastic.
I recommend Floquil Primer from their model railroad line of paints.
It is great stuff.
    January 2004
Posted by MusicCity on Thursday, August 19, 2004 10:36 PM
Mike is exactly right, although we use different brands of primer. Enamel is by far the best way to go because it bonds to the plastic much better than acrylic.
    July 2003
Posted by KJ200 on Friday, August 20, 2004 3:17 AM
I recently tried Vallejo acrylics, and was shocked when they started to lift after mild handling. I've been using Gunze acrylics almost exclusively for the last few months, which from experience do not appear to need priming, as I have encountered no problems what so ever with lifting.
However the Vallejo's apparently do need priming, so I'm thinking it all comes down to which acrylics you're using.
Karl
