metalics question
metalics question
Posted by Anonymous on Wednesday, August 18, 2004 9:54 PM
I have a new eclipse and wanted to know if I use metalics through it, how hard it would be to clean out the metalic paint when I'm done? Would it be better to use a seperate AB to spray just metallics? I don't want to contaminate my new brush with metalic flakes if it's too hard to clean up.
Thanks,
B
Posted by Anonymous on Thursday, August 19, 2004 4:12 AM
with proper thinning youll have no prob. You want your paint to be about the consistancy little heaveir then milk or cream.
    January 2004
Posted by MusicCity on Thursday, August 19, 2004 5:34 AM
Metallics are no different from other paints in that respect. Just clean your airbrush after you use it and don't let the paint dry in it and everything will be fine.
I've had problems spraying some metallic paint through my airbrushes and I think it's just because the metallic particles are just too big. The paint may not spray properly, but it won't hurt your airbrush as long as you keep it clean.
    August 2004
Posted by jdavidb on Thursday, August 19, 2004 6:22 AM
I use an Eclipse too. I do a 100% clean after every color, but many people say it's not even necessary to do it that often. Find some mini brushes that'll fit up in that nozzle and through the gravity plumbing. I think there are some nylon, washable q-tip things in hobby shops, or Badger dabbers. My cleaner brush is now Butler GUM Proxabrush... no more pipe cleaners.
