Airbrush problem....maybe
    September 2003
Posted by KevinCollins on Monday, August 23, 2004 3:06 PM
Hi,
I want to use my airbrush for the first time but seem a little gun-shy of it Blush [:I].....I have hooked it up and blown some air through it a few times to get the feel of it and also tried some test sprays on cardboard....well I figured I'd try spraying water through it instead of just air, well, no water came out....I put some Isopropyl alcohol in and it did spray that.....why wouldn't it spray water... (too heavy??? not enough PSI???).....it's a Testors Compressor that I have.....just thinking about what problems I would've had if I tried to spray some paint.......hhhmmmQuestion [?]. Any ideas as to what is going on....or is it OK?
Thanks,
Kevin
Pray for Surf! Proud sailor (USNR) of IBU 21...NCW Group2
    January 2004
Posted by knight667 on Monday, August 23, 2004 4:30 PM
Could be your water wasn't thinned enough. Big Smile [:D] Just kidding!
What type of compressor is it? Is it the "Blue Ice" compressor?
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    July 2004
Posted by tho9900 on Monday, August 23, 2004 5:54 PM
what type of airbrush is it? I have used the blue testors compressor on occasion and it worked ok... couldn't paint with anything real viscous but it worked. And water blew fine too... If you got an aztec brush you'll need to torque the nozzle a bit more... I have one and learned by trial and error if the nozzle wasn't sealed just right the spray was either intermittent or non-existant.
    January 2004
Posted by MusicCity on Monday, August 23, 2004 6:41 PM
What kind of airbrush is it?
When you sprayed the alcohol did the spray stay the same or did it start out low and get higher? And did you try spraying water after you sprayed the alky? I'm wondering if there was something dried in the nozzle that the alcohol may have dissolved.
I'm not familiar with that compressor, but is there a regulator or any way to adjust the pressure on it? Perhaps it is set too low. Is there a bleed hole (can you hear air escaping when you do not have the airbrush trigger down)? That would affect the volume of air. Is there a leak in your hose connections? Try putting some soapy water on all the hose connections all the way from the comressor to the airbrush. If there is a leak air bubbles will form.
    September 2003
Posted by KevinCollins on Tuesday, August 24, 2004 6:30 AM
I forget the compressor model but it is a Testors.....it's gray and costs about $150....constant running (no tank)......sorry it's kind of vauge....airbrush.....testors as well double action....it's not the aztec but the ones right before the aztecs came out (I think!?!?!)....(I wish I had the box in front of me with the # on it........I'm at work now)........The nozzzle did seem to have a gap between it and the body of the AB but I didn't want to over tighten it and crack the AB...the nozzle was tight too at that point......maybe I need a regulator.....may it did desolve a piece of dried paint.......I'll try water again and maybe another cleaning.........
Thanks,
Kevin
