Paint problem
Paint problem
Posted by Anonymous on Thursday, August 26, 2004 2:04 AM
As I was painting my 1/32 Hornet, I first applied the white basecoat (spray paint) then I masked the panels and painted the outer wings and inner wings (upper and lower, respectivly) blue, and other parts. However, the masking tape [painters mate green] wasn't that good, and as a result, I got lots of seep thru. So, Looking at the instructions, I decided to do a diferent aircraft. So i whip out the spray paint again, cover everything with a nice coat, nothing shows through. Then, After letting it dry for 24-48 hours, bam! there's tons of blue left over, as in "I can see it underneath the white." The spray paint is an enamal, and the blue is testors acrylic. Can anyone help? Thanks
    January 2004
Posted by MusicCity on Thursday, August 26, 2004 5:26 AM
Paint gets thinner as it dries. It isn't uncommon for things that didn't show when the paint was wet and thick to show up when it dries and the solvents evaporate. White is also one of the more difficult colors to get good coverage with. It could also be that the white enamel caused the blue acrylic to dissolve.
You can either try another coat of white or strip it and start over. There is a good chance that another coat of white will cover the blue that's left, but white is a tough color to get good opacity from.
Posted by dubix88 on Thursday, August 26, 2004 5:53 AM
HEY,
I would strip it if i could, but if you dont want to do that add a couple coats of primer and then paint over that.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Thursday, August 26, 2004 12:10 PM
Thanks guys.
I have no detail to protect, since it's raised panel lines. I'll just overcoat it in white, and if not white again
    January 2004
Posted by MusicCity on Thursday, August 26, 2004 12:41 PM
QUOTE: I have no detail to protect, since it's raised panel lines. I'll just overcoat it in white, and if not white again
That'll work ... Give it enough paint and it will either turn white or into one big egg-shaped lump Tongue [:P]
    July 2003
Posted by saltydog on Thursday, August 26, 2004 4:29 PM
primer hides well too ryan. maybe you should try some primer first, then return to the white. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by Jim Barton on Sunday, August 29, 2004 7:45 PM
Light gray primer might work better than white. That's what I would use if I ever had that problem. Let us know how things worked out.
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
