Primer Question
    June 2004
Primer Question
Posted by nicevillescott on Thursday, August 26, 2004 9:16 AM
I'm sure this is a subjective question and everyone has a different opinion on it, but I was wondering what ya'll think about priming every piece of a model before paining. Just spraying everything while it's still on the sprues. Is that a good idea?
    July 2003
Posted by madmike on Thursday, August 26, 2004 9:50 AM
I only prime after main components are assembled.
This achieves two things;
1. checks for flaws and seams requiring more treatment
2. Provides a good "key" for subsequent paint coats
My personal preference is Tamiya fine white or grey lacquer primer from a spraycan. Dries nice and smooth and is tough as nails!
cheers
MikeJ
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    January 2004
Posted by MusicCity on Thursday, August 26, 2004 9:53 AM
You probably don't want to prime the clear sprue Cool [8D]
In many cases it is a good idea, but unfortunately I wind up cutting, sanding, puttying so many pieces that a lot of the primer would be gone. Additionally some types of glue don't stick very well to paint, or if they do the paint pops loose from the plastic, so to be safe you need to scrape the edges where they get glued.
It does work though, and if I did it it would probably help my paint jobs.
    January 2004
Posted by knight667 on Thursday, August 26, 2004 10:02 AM
I've started priming with Krylon flat white lately, and it works great as a "key" (like MikeJ said above) for subsequent coats of paint. I usually prime only after I'm sure I've filled the seams adequately, but sometimes I need to go back and the primer is perfect for that (wish I'd primed my first 1/48 B-17, would have spotted some trouble areas).
Personal choice, but I prefer it now that I've started using it.
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    July 2003
Posted by saltydog on Thursday, August 26, 2004 4:18 PM
i prime after assembling, filling, and sanding too. for resin, i usually prime it after a nice soapy soak, rinse, and dry. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
