How do you adjust a compressors psi?
Posted by Anonymous on Thursday, August 26, 2004 4:18 PM
My compressor has a psi gauge, but is there anyway to adjust to so that it wont go over 30 psi?
    July 2003
Posted by saltydog on Thursday, August 26, 2004 4:25 PM
Ace, there should be a knob located on the compressor with a gauge thats tied into it, turn the knob counter clockwise to decrease the pressure, and the opposite direction to increase the psi. the guage that is attached to the knob should indicate the regulated psi. you should see 2 guages, one for tank pressure, and one for regulated psi. if you don't see a device as discribed, then you may have to purchase one. they can be found at most hardware stores, Walmart, or Home Depot/Lowes. what type of compressor is it, a hobby compressor or industrial? What brand? later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by Anonymous on Thursday, August 26, 2004 5:13 PM
Ahhh I see and get it now. Thanks alot
    August 2004
Posted by jdavidb on Thursday, August 26, 2004 9:34 PM
I like using the kind of regulator that's targeted to airbrushers because it has a more applicable range of 0 to 50 or 60 psi. It makes it more clear of exactly what pressure you're airbrushing at. My compressor has the larger range gauge on it, 0 to 200, and its under 30 psi readings are quite off when compared to the airbrush regulator which is right after it.
Posted by MikeV on Thursday, August 26, 2004 10:01 PM
David,
Good point.
I have been meaning to get a different gauge for my Badger Million-Air as I prefer the gauges that read down to single pounds instead of 5 lbs at a time.
Posted by Anonymous on Thursday, August 26, 2004 10:53 PM
My Regulator for my CO2 only reads in 10 lbs slots heh. But I am soo accustomed to feeling the air anyways that I usually nail it.
Whats that old saying... "use the force luke... use the force"
    August 2004
Posted by jdavidb on Friday, August 27, 2004 4:54 PM
Mike: the gauges that are on my supposed-to-be-a-Badger regulator have only 3 notches between the 10's, so you'll have to shop around to find all nine notches. I don't know of one that has that. I didn't shop around as you can probably guess since I paid $55 for whatever this is.
But, to the original poster: don't let this make ya feel like you need some $55 piece of equipment to do what you want to do. It's a lot cheaper than that.
Posted by Anonymous on Friday, August 27, 2004 5:11 PM
Good points, I bought my gauges from Grainger they have nice little gauges that are ideal for airbrushing. The only problem is I think they don't sell to the general public. One thing I noticed is that I have never been able to get the same readings from different gauges that I have tried they are plus or minus 2-5psi of each other. I only know this because I used an expensive calibrated gauge from work to check them out after the pressure in the one just didn't seem right. I made a mark at 25psi on the gauge I use now to get a better idea but like woodbeck3 I usually go by feel with the air pressure.
John
    July 2003
Posted by saltydog on Friday, August 27, 2004 5:41 PM
john, i too bought my reg, and moisture traps from Grainger. i've had no problems with them, and my reg. gauge is 0-60, but adjusting the pressure below 10 psi is sketchy to say the least. i'm like Jeff, just kinda "feel" the air. later.
Posted by MikeV on Friday, August 27, 2004 8:29 PM
I agree with kind of feeling the air also, so another gauge is probably not necesssary.
    July 2003
Posted by saltydog on Friday, August 27, 2004 10:04 PM
mike, you've been airbrushing so long and doing so many different types of work with an airbrush, you could probably adjust it without looking!!LOL i know i can "listen" and spray on some scrap til i get it like it want it, and the needle on the gauge is well below 10 psi when i look over there to get a reference for the next session. but thats dealing with free hand camo and stuff, normally i'm spraying around 12 to 18 psi for general stuff. for T-shirts, i used to spray at about 80 psi!!LOL that would blow the kit apart!! thats been a long, long time ago though. later.
Posted by MikeV on Friday, August 27, 2004 11:59 PM
I hear you Chris.
I guess I was thinking that it would be nice to have a reference for telling people what pressure I had the best results with, but as John said in his post, different gauges can show different readings with the same pressure applied.
That makes the gauge reading almost useless to someone asking for what pressure you spray at. I basically just use it as a reference point and then adjust up or down from there depending on the results I get.
Posted by Anonymous on Saturday, August 28, 2004 2:03 AM
Wow Chris over 80 on T-shirts!!! you shootin cement then??? I barely hit 55-60, unles its white I am shooting. plus I also use sometimes when the effect is called for ...my Arts paint (Comair) which I can put on shirts all the way down in single digits for psi
