- Member since
August 2004
Posted by jdavidb
on Friday, September 3, 2004 9:41 AM
On the compressor side of the Iwata air hose is 1/4" npt female, but you should probably be aiming to adapt to 1/4" closer to the compressor. Your airbrush line already fits airbrush regulator/gauge/moisture traps. Somewhere between the compressor and the regulator is where to put the adapter to get things to the 1/4" size.
