Mike... ok my friend you have done it!!!
I'm buying that second airbrush... one with the soft pull for the major painting and one for stuff like that!!!
(next time my wife goes on an all weekend karate training camp of course)
interesting point and I will have to try some test patterns to see how mine fairs... I don't have it soft or anything... I just backed off a bit on the tension... with the long pull on the crescendo (longer than my previous brush at least) as I got closer to the max point on paint flow the more I had to press down to maintain the point I was at in the back pull... with it softer now it is one even motion... Not to say I was using max paint flow because on my brush that would be a lot.. but the further I pulled back, it seemed the more I had to maintain down pressure to keep it there...
I am sure in time I will be used to this... but I definitely want to try out the pattern you showed me to see if it can still do it... I could handle a little more on the pressure side to be able to acheive that pattern...
and thanks for the info by the way! I have been experimenting with another way of doing that but yours seems much easier!!!
P.S. you ought to think of doing a 'learn to airbrush' for models.. haven't seen one out there really, only thing I have seen is illustration and T-shirts... and it definitely would help with some of the finer tricks of doing a good model... without having to go through 10 kits to find out the best way... (might make some money off of it... who knows?)
