Airbrush wont spray paint (Similiar to harbormasters problem)
Posted by Anonymous on Saturday, September 11, 2004 2:33 PM
My problem is almost exactly the same as harbor masters. Except that it wont spraly anything now even though the needle is straight, the hole in the glass jar is open, the air is steady and not pulsating, and the head is on tight and not leaking. Any ideas?
    March 2004
Posted by bstrump on Saturday, September 11, 2004 3:01 PM
Is yours a gravity feed or siphon feed? Perhaps you didn't thin the paint enough or your comp[ressor isn't putting out enough. Anyhow, If you can be patient, MikeV should be around shortly to help
Posted by Anonymous on Saturday, September 11, 2004 3:06 PM
Now its not spraying anything at all. It was spraying fine yesterday, but it always sprays the paint really thin when it does.
    March 2004
Posted by bstrump on Saturday, September 11, 2004 3:10 PM
Sounds like maybe there's a blockage. I have a Badger 200 and when it does the same thing I turn it upside down and put some lacquer thinner in where the jar plugs in and spray. I do this a couple of times and it clears it out. Hope this helps.Smile [:)]
Posted by Anonymous on Saturday, September 11, 2004 3:15 PM
This seems like the month for air brushes to unite against their masters and i dont like it!Disapprove [V]Banged Head [banghead]Evil [}:)]Black Eye [B)]
Posted by Anonymous on Saturday, September 11, 2004 3:17 PM
Mike is the man he should have an idea or he will point you in the right direction. Ive learned so much since i posted this topic all from him.Cool [8D]
    July 2004
Posted by tho9900 on Saturday, September 11, 2004 3:38 PM
What kind of airbrush is it?
Posted by Anonymous on Saturday, September 11, 2004 3:39 PM
I just tried spraying some paint remover through it (its siphon fed) and it started to spray water again, but then stopped shortly after.
Posted by MikeV on Saturday, September 11, 2004 4:03 PM
Buy a Badger and then I can help better. Big Smile [:D] Wink [;)]
Seriously though, as Tom asked, what airbrush is it?
Posted by Anonymous on Saturday, September 11, 2004 4:28 PM
To be honest I really have no clue Big Smile [:D] But, looking at badger pictures, it looks very simiiar and has similiar parts.
Posted by MikeV on Saturday, September 11, 2004 4:41 PM
I think you and Harbormaster should both buy an Omni 4000. Tongue [:P]
If you two can swing the price of the airbrush then I have 2 extra hoses you guys can have for them. Wink [;)]
Posted by Anonymous on Saturday, September 11, 2004 4:50 PM
Mike where were you when i bought my paache you are not funny! Just kidding RichEvil [}:)]
    July 2004
Posted by tho9900 on Saturday, September 11, 2004 5:24 PM
Actually off topic of AoS's broken airbrush, but after using my Crescendo with the metal paint cup, I am dying to get hold of a gravity fed brush.... In fact that's all I've used on it since I got it, the paint cup... it helps because I use the one off the 350 I had as a spare for cleaner once I am done with the color... ( Disapprove [V] I know.. I know... shoulda listened to yall...)
AceofSpades - do you have a digital camera and could post a pic of it? If not, is it single action, double action? Internal mix or external mix?
    August 2004
Posted by jdavidb on Saturday, September 11, 2004 5:36 PM
wait 'til ya see what I bought.
Posted by Anonymous on Saturday, September 11, 2004 7:44 PM
Well what do you know, I decide to try one last time to see if it will spray and it sprayed perfectly. Funny how these things work sometimes huh? Unbelievable. Oh, and harbor, basically all I did was spray alot of paint remover through it, reposition the needle, and let it dry. You never know Big Smile [:D]
