Alclad II
Alclad II
Posted by pingtang on Thursday, September 16, 2004 10:45 PM
G'day
I'm about to use alclad lacquers for the first time and have a few questions.
I'm going to use #101 Aluminium. Do I need to have a black primer for this lacquer? or will a grey primer do? What flat coats can and can't be sprayed over alclad? And fianlly, what should I use to clean my airbrush with afterwards?
Thanks in advance.
-Daniel
Posted by Anonymous on Friday, September 17, 2004 12:10 AM
you should ALwAYS use a gloss black primer, makes the coats smoother. at least for bmf finishes.
as for cleaning, I suppose you could use lacquor, but that is highly damaging to your airbrush seals, if you use an older Iwata or aztek or omni, but if you use a badger I suppose it would be ok... just ask mikeV on advice. I would think acrylic and enamal flat coats can be added on top, since lacquer is 'stronger' then them both. Just ask somebody.
    August 2004
Posted by jdavidb on Friday, September 17, 2004 7:58 AM
It can't be gray, and it can't be regular black primer because that is flat/matte. It has to be gloss black. Swanny's site says to use Krylon gloss black, but I'm about to test Tamiya TS black synthetic lacquer in a few days as the gloss black backer. I don't know what's available in Australia.
    August 2003
Posted by tweety1 on Saturday, September 18, 2004 2:31 AM
Ping, I use both the grey primer, it helps to show up the ugly spots that will stick out after the BMF is done.
The the Alclad Gloss Black,, sanded smooth as a bubbas bot bot!
Then the BMF in which ever tone.
Living in Aus, we really dont have the access to all the funky stuff the yanks get to play with, so whenever I use paints, I try my best to use all of the same brand, and in the way the manufacturer intends.
Some may argue, but I have never gotten anything other than 1st in all my show entries, so something must be right!
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by rjkplasticmod on Saturday, September 18, 2004 10:15 AM
A gloss black primer works best with Alclad2 Aluminum. I have experimented with both medium grey & white gloss as an undercoat, which does give detectable color variation, but the gloss black gives the most realistic finish. Alclad2 is a lacquer, so you have to use lacquer thinner for clean up. Once cured, you can top-coat with Future or any enamel/acrylic/lacquer you choose. Top coating does somewhat reduce the metallic appearance however.
Regards, Rick
Posted by Anonymous on Monday, September 20, 2004 1:16 PM
And once it has cured (at least 48 hours) you can paint and mask away to your hearts desire with any brand/make of paint you like, top coated or not.
Posted by pingtang on Monday, September 20, 2004 8:18 PM
Thanks for the help guys. Has anyone tried Tamiya spray can gloss black as a primer for alclad?
-Daniel
    July 2003
Posted by saltydog on Tuesday, September 21, 2004 3:53 PM
as long as the primer is lacquer based, you can use any brand you want. i reccomend staying with alclad primers as they have given me the best results. i've used alclad grey primer on things like wheel wells, landing gear, and odds and ends pieces on the mustang, and it turned out great. if you want a dull aluminum look, then you should go with the grey primer, but if you are wanting a nice, shinny metallic look, then go with the gloss black primer. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
