from what I am reading this stuff should work fine.. it sounds like the acrylic version of laquer thinner:
_____________________________________________________
>>>>Ethylene glycol monoethyl ether is used in varnish removers, lacquers, and as a solvent for printing inks, duplicating fluids, and epoxy. Ethylene glycol monobutyl ether is used in hydraulic fluids, as a coupling agent for water-based coatings, in vinyl and acrylic paints and varnishes, and as a solvent for varnishes, enamels, spray lacquers, dry cleaning compounds, textiles, and cosmetics.
Propylene glycol monomethyl ether is primarily used in the manufacture of lacquers and paints, as an anti-freeze in industrial engines, a tailing agent for inks used on very high-speed presses, a coupling agent for resins and dyes in water-based inks, and a solvent for celluloses, acrylics, dyes, inks, and stains. It is also used in cleaning products such as glass and rug cleaners, carbon and grease removers, and paint and varnish removers; and in pesticide formulations as a solvent for applications to crops and animals.<<<<
the basic dangers of this:
>>Inhaling glycol ethers can result in dermatitis with erythema, edema, and weeping; hyperpigmentation; and photosensitization.
(read: a really bad rash, swelling of the body including fluid seeping out of your skin, changing skin color to a darker shade, and aversion to bright lights)
Exposure to ethylene glycol monoethyl ether can cause depression of the central nervous system, resulting in headaches, drowsiness, weakness, slurred speech, tremor, and blurred vision.
Ethylene glycol monobutyl ether is regarded as the most toxic glycol ether used as a solvent. Exposure can result in bone marrow damage, headaches, drowsiness, weakness, slurred speech, tremor, and blurred vision. Exposure to vapors can result in respiratory, nose, throat, and eye irritation.
('nuff said)
Exposure to propylene glycol monomethyl ether can cause eye, nose, and throat irritation. High levels become objectionable because of the chemical's odor. <<
