HELP my Aztek has died
Posted by Anonymous on Monday, September 27, 2004 5:44 AM
G'Day all,
My Aztek A308 has decided it doesn't want to work anymore. It seems to have an airleak inside the body and when I try to paint it doesn't... if you know what I mean... no paint comes outDead [xx(]. It also blows bubbles inside the paint cup. I have changed the tip to no avail.
Thanks in advance...
Nathan
    August 2003
Posted by tweety1 on Monday, September 27, 2004 8:05 AM
Sorry to hear thatSad [:(]
Sounds like it's time to send it in for repairs.
Do you mean the A4308?
Did you spray any Lacquer based paint through it???
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by Anonymous on Monday, September 27, 2004 2:10 PM
It could just be clogged. Have you taken the tip off, and pulled the needle and spring out to see if they are gummed up?
Dan
Posted by ABARNE on Monday, September 27, 2004 2:42 PM
Since you've eliminated paint tip problems by switching tips, I assume you have also cleaned the body in accordance with Testor's instructions, and verified your air supply, (not that a clogged hose or insufficient pressure would cause bubbles in the paint cup. Your problem sounds like my My A430 which went kaput in a manner similar to what you are describing. I e-mailed Testor's customer service and was told:
QUOTE:
Please send the airbrush BODY ONLY:
Testor Corporation
ATTN: Airbrush Warranty/ Customer Service
440 Blackhawk Park Ave.
Rockford, IL 61104
Please include a note with name, address, daytime phone number and or and e-mail address and a brief description of the problem.
We recommend that the airbrush be sent UPS, FedEx or certified mail so that you will have a tracking number to verify that we received it.
This tracking number will verify that we received your airbrush and that it didn't get lost in the mail.
It will take approximately 2 weeks to process your request. If your airbrush model is one backorder, it will take another 1 -2 weeks longer.
Although the break-down was irritating, and it ended up taking about 3-1/2 weeks to get the replacement, to Testor's credit they did given me the replacement air-brush with out trouble.
Andy
    July 2004
Posted by tho9900 on Monday, September 27, 2004 6:14 PM
I'd make sure the little hole in the paint jar lid isn't clogged, it happened to me once... had me looking at the thing for hours before I noticed it... kind of obvious but I am just grasping at straws right now...
I have also had success removing the needle itself from the nozzle, checking for dried paint, cleaning and reinserting it... I think the reinserting it is what did it...
Posted by Anonymous on Monday, September 27, 2004 7:23 PM
time for a badger
Posted by darson on Tuesday, September 28, 2004 12:33 AM
Sign - Welcome [#welcome] to the FSM forum Nathan. Drop on over to the Aussie Modelers section in General Discussion and say hello.
I had an Aztec A470 for a number of years and experienced both the problems you are having, but I don't think my solutions will help at all.
Bubbles in the paint cup always meant that the tip was not tightened correctly and no paint coming through usually meant that the needle was jammed in the tip.
QUOTE: It seems to have an air leak inside the body
This seems like a real problem that can be only be handled by either a return to manufacturer, or if you are feeling game check out the following. http://www.master194.com/maquettes/autres/aztec.htm
Please note that Testors do not recommend taking their airbrushes to bits, so please don't blame me if something goes wrong.
I agree with 1337, if you are considering a replacement look at a badger, Paasche or an Iwata.
Cheers
Darren
    July 2003
Posted by KJ200 on Tuesday, September 28, 2004 3:44 AM
Sounds like a heaven sent opportunity to trade up to a Badger or an Iwata.
Karl
Posted by dtraskos on Tuesday, September 28, 2004 9:32 AM
All airbrushes seem to work in one of two ways. They mix the paint and air internally or externally. Even the "Almighty Iwata" does. They all have a pathway for air and a pathway for paint. Iwata included. If either one of these pathways is obstructed, even partially, the airbrush will not operate properly. If there is paint that was allowed to set up in the paint pathway, the thinner that was used to bring it to the proper spraying viscosity will, most likely not disolve this and a stronger solvent will have to be used. I have very small diameter brushes and small diameter music wire for cleaning . The solution to an airbrush that has stopped working is not Iwata, Badger or some other brand of airbrush, but finding the blockage in the one you are having a problem with. It is very possible for every airbrush,even Iwata, to get obstructed in either the air path or the paint path.
I have, over the years, obtained Badger, Paasche, IWATA, a no name gravity feed double action I bought at a swap shop for 5 dollars and they all work fine. I can also make everyone of them quit working, but that would come under the heading of "pilot error". Which means it was my fault and not because of the brand name on the airbrush.
I`m of the opinion that if you get to learn how your airbrush works, how the air goes through and how the paint goes through you will be much more able to take care of the problems that arise.
The reason I mentioned Iwata the way I did is a lot of people seem to think of it as the "Holy Grail" of airbrushes. It is a very fine airbrush, but it can sputter, spit ahd spray to one side just like any other one. It depends on the operator and not the brand name.
Dave
Posted by MikeV on Tuesday, September 28, 2004 7:25 PM
Very well said Dave, although I would still never own an Aztek because they are problematic for many people, even the ones who clean them well. Wink [;)]
If they must be disassembled to clean them properly then what is the advantage of them? I see none other than a different shaped airbrush.
It's a shame that so many buy these because of deceptive advertising, but I guess that's true of anything.
Posted by dtraskos on Wednesday, September 29, 2004 6:26 AM
Mike,
I agree with you. I`m from the old school. Some things should not be made of plastic. Airbrushes are one of them.
Dave
