siphon cup caps?
siphon cup caps?
Posted by Anonymous on Tuesday, September 28, 2004 6:12 PM
do these exist anywhere? I keep spilling paint because i practically whip my hand around. if anyone with a lathe can be so kind as to.....
    January 2004
Posted by MusicCity on Tuesday, September 28, 2004 8:28 PM
Siphon cup caps? I'm not even sure what those are Confused [%-)] Do you mean caps to screw on the bottles? Or do you mean gravity feed cup caps?
Posted by MikeV on Tuesday, September 28, 2004 8:56 PM
Put a piece of duct tape over it and put a small hole in it for air. Clown [:o)] Big Smile [:D] Wink [;)]
Posted by Anonymous on Tuesday, September 28, 2004 9:52 PM
Scott, I think 1337's referring to (metallic) cups similar to those used on Badger 350's. The siphon tube is part of the cup body and extends from the bottom of the cup upwards.
1337, I recall Aztek side feed cups have caps included with them. Perhaps you can buy a spare cup set and just cannibalize the cap for your siphon cup's use (not sure though if they will fit). Sorry I have not yet come across a commercial product as you specified. Hope this helps.
Suggestion: How about using a rubber stopper with a hole drilled in the middle? Rubber of course should be impervious to the harshest chemicals that you'll be using, such as lacquer.
Cheers,
onyan
Posted by Anonymous on Tuesday, September 28, 2004 10:00 PM
I'm sure they don't fit.
scott, i refer to tthose siphon cups, a cap for those. i was wondering if anyone made those or had those. the duct tape idea is ok, i just don't like using duct tape on art.
    January 2004
Posted by MusicCity on Wednesday, September 29, 2004 5:26 AM
Oh, OK, now i'm with you. I've even got a side feed cup for my Omni 3000 and didn't even think about it.
Look around the house and you might find something that will fit; pill bottle caps, anything round and cup-shaped. A piece of aluminum foil held on with a rubber band. I like Mike's duct tape idea myself.
