Air Tank?
Air Tank?
Posted by Anonymous on Wednesday, September 29, 2004 12:09 PM
My Iwata SmartJet is working great after adding a real regulator. The pressure is constant and the auto off switch works.
But I am just curious. Will adding a separate air tank make any different? If so, what's a good size and where to find it?
    January 2004
Posted by MusicCity on Wednesday, September 29, 2004 7:57 PM
If it ain't broke, don't fix it.
A tank simply acts as a buffer. The tank is pressurized by the compressor, and the air in it is used by the airbrush. When the pressure in the tank gets lower than the trip pressure on the compressor, the compressor comes back on and repressurizes the tank.
If you are having pulsation problems from your compressor a tank will smooth those out. If the outlet pressure of your compressor (with no regulation) is significantly higher than what you normally paint with your compressor would probably run a little bit less, but not a lot in the long run (since you normally end the day's painting with a full tank of air and bleed that off without using it, the run time used for that pressurization is wasted). Otherwise if your compressor is doing what you want I don't really think you'd accomplish a lot by adding a tank.
    August 2004
Posted by jdavidb on Wednesday, September 29, 2004 9:33 PM
I don't think a Smartjet will push hard enough to significantly utilize a tank's ability. A (usual) tank can hold around 150 psi, and that is where the longevity comes from as far as giving the compressor motor shut-off relief time. With a large tank (over 2 gallons), you might end up running the Smartjet more than usual in order to do the initial tank fill up opposed to just letting the Smartjet do its usual auto on/off job. That's probably why that type of compressor never comes with a tank larger than 1 gallon... an example would be the Badger Millionaire. It has a tank, but it's only something like a half gallon.
Posted by MikeV on Wednesday, September 29, 2004 9:44 PM
I would agree David and I have a Million-Air compressor. Big Smile [:D]
That poor Iwata would work so hard to fill an airtank that it would probably die a premature death. The Million-Air does have a bigger compressor motor but it still does not need a larger tank as that would hamper it's design.
The advantage of an airtank that is suitable for the compressor is that it gives the motor a time of rest to prolong the life of the compressor, as heat is what kills them. A compressor like my Million-Air has a 50% duty cycle which means that it should be off as long as it is on to have the most longevity.
The automatic types like the Iwata last fairly long also, but they don't have that cooling time that a tank compressor has along with being oil-cooled like many silent models.
Posted by Anonymous on Wednesday, September 29, 2004 9:46 PM
mike, what if you rip it open and put in a corvette v8?
Posted by MikeV on Wednesday, September 29, 2004 10:27 PM
Then it becomes substantially louder than the 30 dB it is now. Laugh [(-D]
Posted by Anonymous on Wednesday, September 29, 2004 11:16 PM
what time is it ? its TOOL TIME ! MORE POWER ! thats right 1337, you have the idea, heck about the noise, stick in those ponies ! Big Smile [:D]
Posted by Anonymous on Wednesday, September 29, 2004 11:19 PM
screw the 1/8 hp! go 400! infact, use the exhaust and air output to power the turbo's
Posted by MikeV on Wednesday, September 29, 2004 11:19 PM
If you want power forget that Chevy engine, it is weak.
Put a Caterpillar engine in that baby instead. Thumbs Up [tup]
Posted by Anonymous on Thursday, September 30, 2004 11:01 AM
Thanks guys. I got my question answered by the second reply and was wondering what more can be told in the rest of the 8. Smile [:)]
    January 2004
Posted by MusicCity on Thursday, September 30, 2004 12:15 PM
QUOTE: Thanks guys. I got my question answered by the second reply and was wondering what more can be told in the rest of the 8. Smile [:)]
You didn't really think a topic in this area was going to stay exactly on topic, did you?
Posted by Anonymous on Thursday, September 30, 2004 6:04 PM
airbrushing: the offtopic crew
Screw the cat engine, go vought r2800 24 cylinder 2000+ hp
Posted by Anonymous on Friday, October 1, 2004 9:03 AM
where is the GE nuclear turbines when you need them ? enough power in your AB to shoot paint across the room ! enough PSI to power all the airbrushes in the world! MUHAahahaha !
Posted by Anonymous on Friday, October 1, 2004 9:11 AM
OK. I will join the fun here. Smile [:)]
I would guess it will shoot through the plastic.
    May 2003
Posted by qmiester on Friday, October 1, 2004 5:45 PM
Has anyone looked into the possibilities of using an attorney or politician as an airsource for airbrushing?
Quincy
    January 2004
Posted by MusicCity on Friday, October 1, 2004 6:36 PM
QUOTE: Has anyone looked into the possibilities of using an attorney or politician as an airsource for airbrushing?
Interesting ... in inexhaustable source of compressed air. The biggest problems that I see are 1) It would be far too loud to leave indoors, and 2) It has no on / off switch.
Posted by Anonymous on Friday, October 1, 2004 7:04 PM
dont forget that the fact that since the air is hot , it might render the PSI inconsistent, perhaps you would need to fit a regulator.
