Tamiya Fine Surface primer **MIGHT** work. The can states that it is for plstic or metal, but it is enamel and is not going to be very flexible. If you flex the foil it is probably going to flake off.
I would try some automotive primer. That stuff is designed to stick to most metals and has to be relatively flexible so it should work OK. I'm not sure you'll find anything that works perfectly though.
