QUOTE: how do u guys test ur paint?
I spray mine to test it. If it sprays at the pressure I want to use and covers properly then it is thinned properly.
I've said it before, and I'll probably say it again. Thinning is, in my opinion, very much a matter of personal preference; there are no rules. Pick a pressure that you want to spray at, within reason, and thin the paint enough so that it sprays properly and covers properly at that pressure. If you don't have to thin it at all to get it to spray, so be it. If you have to thin it 1:1, so be it. What counts is how the paint looks on the model, not how much you thin it.
Start about 15 psi and get the paint to do what you want at that pressure. When painting very close, as when doing soft-edged camo, reduce the pressure a little and thin the paint a little more.
