Primer Question
    June 2004
Primer Question
Posted by nicevillescott on Friday, October 1, 2004 11:51 AM
What's the best way to apply primer? I use rattle cans but the last time I sprayed a model I sprayed too much and obliterated some detail. Is there a trick to using rattle cans?
    January 2004
Posted by MusicCity on Friday, October 1, 2004 12:10 PM
Fast hand motions and spray from a distance so you get light coats. Rattle cans have a lot of pressure and a lot of flow, and it's easy to lose surface detail with them.
    June 2004
Posted by nicevillescott on Friday, October 1, 2004 12:26 PM
Thanks. I'm spraying a Spitfire tonight and I don't want to mess it up. Can primer be applied with an airbrush? I don't think I've ever seen just bottles of primer (like paint), but then again I'm not sure if I've ever looked for it, so I might have.
    January 2004
Posted by knight667 on Friday, October 1, 2004 1:32 PM
Testors makes a MM primer, it comes in gray and white (and it's expensive...the usual $2.49 for a 1/2oz MM-sized bottle). I've used Krylon rattlecans in the past, but recently have been using MM light gray and it seems to work pretty well. Other people might have other/better advice. Big Smile [:D]
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
Posted by Anonymous on Friday, October 1, 2004 3:49 PM
You can also decant the primer that you buy in rattle cans. Swanny has some good tips on his site for this. He does it with the Krylon before applying a nmf with Alclad. Check it out here: http://www.swannysmodels.com/Alclad.html
~ Garth
Posted by Anonymous on Friday, October 1, 2004 7:15 PM
you dont need coverage with primer, all you need is to coat the surface with microscopic amout of the primer so the paint bites. just a very light mist will do, we are not looking for color, just the actual presence of the primer. the primer in a bottle is designed to be sprayed with an AB and it also works great for filling small gaps. emphasis on small Tongue [:P] hope your spitfire turns out good Smile [:)]
