having a problem after i strip paint off of one of my models!!!
Posted by Anonymous on Monday, October 4, 2004 4:48 PM
i strip my model body but all of the blue didnt come off its still on there so...i got it back in the simple green to see if it will get off but i wanna ask can i use the model thinner to take all of the blue off that didnt wanna come off whatever???
Posted by Anonymous on Monday, October 4, 2004 5:50 PM
after its got some simple green on it, scrup it with an old toothbrush or something similar. paint tends to be really stubborn so youll have to use some elbow grease, but it should come off. good luck. later.
Jon
    May 2003
Posted by qmiester on Tuesday, October 5, 2004 6:00 AM
As Ron has said, soaking the model a second time and using an old toothbrush should work very well for you. On occasion, a particularly stubborn area may require an application of very fine sandpaper (800 or finer). However, what ever you do, don't use thinner to remove the paint as it will melt the plastic. (Most of the liquids used to thin acrylics won't effect the surface, but by the same token, won't effect the paint either). If you want to see for yourself, take a small piece of sprue from the kit, put it into a glass jar, pour in enough thinner to cover the sprue, put the top on the jar and let it set for a couple of hours and see what happens.
Quincy
Posted by MikeV on Tuesday, October 5, 2004 7:14 AM
Pick up some Castrol Super Clean and that paint will be off in a couple of hours. Thumbs Up [tup]
Posted by Anonymous on Tuesday, October 5, 2004 8:06 AM
im talking about the model master thinner that is for models, i didnt want to soak the model in the thinner i just want to put some on something and clean the blue whatever if i had a good cam that took pics i'll take one and show u what it did b/c i got all of the blue paint off of it but like its molded in the model body's parts like
