What Can I Use Instead of Testors Dullcoat?
Posted by Anonymous on Sunday, October 10, 2004 8:50 PM
What are a couple of different things I can use instead?
Posted by rjkplasticmod on Sunday, October 10, 2004 9:23 PM
Try Polly Scale Clear Flat. It's an acrylic & works very well. I used Dullcote for years, but have now switched to Polly Scale & am very satisfied with the results.
Regards, Rick
Posted by Anonymous on Sunday, October 10, 2004 9:24 PM
You can use Gunze Sangyo Hobby Color Acrylic Clear Flat or Polly Scale Acrylic Clear Flat. Both products are water-based acrylics and won't affect decals or paint if laid on too thick, and a lot safer to use, too. Thin them with acrylic thinner such as Tamiya's X-20A thinner. I've personally used Gunze Flat and had good results.
You can also use a mixture of Tamiya Acrylic Flat Base and Future floor polish. For a complete discussion of the mixing ratios, head on to Swanny's site:
http://www.swannysmodels.com/TheCompleteFuture.html
Hope this helps.
Cheers,
onyan
Posted by MikeV on Sunday, October 10, 2004 10:20 PM
Model Master Acryl Clear Flat is also good.
Posted by Anonymous on Sunday, October 10, 2004 10:40 PM
yeah what was mentioned above Big Smile [:D]
Posted by Anonymous on Sunday, October 10, 2004 10:45 PM
So is dullcoat the same thing as a flat paint? And, does dull coat actually dull the paint?
Posted by pingtang on Sunday, October 10, 2004 10:54 PM
I like Gunze-Sangyo Aqueous flat clear.
-Daniel
Posted by MikeV on Sunday, October 10, 2004 11:00 PM
Yes. Dullcoat is a lacquer-based, flat clear that dulls the finish of the model.
The Polly Scale and Model Master Acryl that was mentioned do the same thing except they are acrylic-based.
Posted by Anonymous on Sunday, October 10, 2004 11:15 PM
And they sure as heck smell alot better than Testors Dullcoat!Smile [:)]
    July 2003
Posted by KJ200 on Monday, October 11, 2004 2:16 AM
Works for me.
Karl
Posted by Anonymous on Monday, October 11, 2004 5:27 AM
just bear in mind that testors dullcote is good to preserve your model. since its laquer based, a drop of water that was contaminated with a tiny bit of isoprop alcohol wont do nuts to it, but if you let anything touch say gunze flat it will just take the flat rigth off. i use gunze flat and it isnt fantastic. but as was said earlier, it is less toxic than dullcote. alot less.
    July 2003
Posted by madmike on Monday, October 11, 2004 7:26 AM
Pollyscale flat is about the nicest flat clear on the market!
Easy to apply and thins with distilled water...
Recommended!!
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    November 2003
Posted by roosterfish on Monday, October 11, 2004 9:05 AM
I'm different. I go around the corner to Michael's Arts & Crafts store and pick up a large 11 oz. can of Krylon Matte Finish. The can advertises the the spray, "Eliminates Glossy Sheen, Creates a Soft, Satin Finish.
The can only costs a couple of $$, I get a lot, and it works as good as any other small, expensive, can labeled for modelers.
Winners never quit; quitters never win.
