alclad, if used correctly, is certainly the way to go when it comes to metal finishes. its not that complicated really. the surface has to be nearly perfect is the major step, then the rest is just airbrush skills. do the lacuer gloss coat, and i use the alclad gloss black base, let that cure thoroughly (24 hours or better), then apply the alclad metalizer in light coats. works great everytime. later.
