Hi everyone,
I've just sprayed a couple of coats of aclad 2 aluminium on my P-47 and the coat looks uneven. What I mean is, some areas are darker than others. I think it is because the level of gloss is higher in the areas that look brighter and flatter in the dark areas. Am I correct in assuming that this is the problem? and will a coat of flat or gloss clear even things up?
Or should I just spray another coat? And if so, how can I make sure the coat goes on smoothly with the same finish in all areas? Am I spraying it wrong?
Thanks in advance for any answers you can give me.
