Bare Metal Foil Application
    November 2003
Posted by JoeRugby on Thursday, October 28, 2004 8:46 AM
New to the boards, not sure if this belongs here or elsewhere...but here goes anyway...
I am taking on my first extensive bare metal foil finish. Is there any recomendation as to whether or not a rinse or surface prep wash is advaisable before application???
Check out the WW I Special Interest Group @ http://swannysmodels.com/yabb/YaBB.pl?board=WW1SIG
    August 2003
Posted by tweety1 on Thursday, October 28, 2004 9:25 AM
The most surface preperation you will want to do is to wash your model thouroughly, and make sure there are no imperfections on the kit, as these WILL stand out like a sore thumb.
Secondly, make sure there are no bits of dust or hair on the area yu are about to cover with foil, as these will also stand out.
Take a small piece of foil and cover a part of your model that has obvious dust bits etc on it, this will allow you to see and judge just how clean your kit has to be.
Hope this helps
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
