testors laquer dull coat
Posted by Anonymous on Thursday, October 28, 2004 6:26 PM
Can anyone give me an idea of a good ratio of laquer dull coat to laquer thinner. I will be air brushing this with my Aztek A470.
thanks,
mahoney
Posted by rjkplasticmod on Thursday, October 28, 2004 7:09 PM
It really depends on your AB & compressor set up. I never thinned it more than 2 Dull Cote to 1 thinner. Sprayed between 15-20 psi with a Paasche H3. Don't use it anymore, having fell in love with Polly Scale flat.
Regards, Rick
Posted by Anonymous on Friday, October 29, 2004 6:24 PM
Thanks Rick. I've used this before but I mixed up a big batch and once it ran out I forgot the ratio. I'll have to try the polyscale flat. Is that acrylic? I use their acrylics almost exclusively and have had great results.
thanks again,
mahoney
    May 2003
Posted by styrene on Friday, October 29, 2004 10:26 PM
I use it straight from the spray can---both from the can to the model, and from the can to the color cup of my airbrush (Spraying through a straw or applicator--like you get with WD-40) helps keep down overspray and wasted material. Don't have to worry about thinners, ratios, or anything else.
Gip Winecoff
Posted by rjkplasticmod on Saturday, October 30, 2004 9:37 AM
mahoney, Polly Scale flat is an acrylic & the best flat finish I've ever used.
Regards, Rick
