Lacquer over enamel?
    August 2004
Posted by Tankmaster7 on Friday, October 29, 2004 9:06 PM
Is it okay to spray testors glosscoat lacquer and dullcoat lacquer over enamel finishes?
Thanks, Tankmaster
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    July 2003
Posted by Foster7155 on Friday, October 29, 2004 9:37 PM
Been doing it for years with Testors Dullcoat...no problems that I've ever encountered.
Enjoy your modeling...
Robert Foster
Pensacola Modeleers
    May 2003
Posted by styrene on Friday, October 29, 2004 10:28 PM
It is completely OK. Just make sure your enamel is sufficiently dry.
Gip Winecoff
    July 2003
Posted by madmike on Saturday, October 30, 2004 12:08 AM
Thin layers, mist it on otherwise the lacquer will soften and craze the enamels.
The golden rule is lacquer/enamel /acrylic but I have found that thinnly applied coats will allow you to break that sequence.
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    August 2004
Posted by Tankmaster7 on Saturday, October 30, 2004 9:50 AM
OK good, because I think I read somewhere that the lacquer could wrinkle the enamel or something. But the lacquer seems to be really agressive. Maybe I'll switch to the MM acryl gloss and dullcoat. Thanks a lot.
    July 2003
Posted by madmike on Saturday, October 30, 2004 7:20 PM
If you can, try Pollyscale's range of clear. Excellent stuff !
cheers
Posted by ajlafleche on Saturday, October 30, 2004 10:59 PM
I use a lot of acrylics in my figure. I'm just finishing one that was going to have decals and needed a gloss coat. Shot a very heave coat of Glosscote with no problems. The othe guy I'm finishing up just got a heavy application of Dullcote, again, with no problem. Of course, both had been sitting for a couple days since tha last applicationos of either oil or acrylic.
These two products would be more of a problem if you brushed them on rather than airbrushing.
