I have a VL and a Badger 100. Personally, I think the VL is a pretty good all around airbrush. I like the Badger 100 a bit better, but the VL is nothing to sneeze at. A few things I'd suggest:
- if it's been sitting around for a while, give it a good cleaning.
- check the needle to be sure it's not bent. If so, replace it (Paasche parts are pretty easy to find)
- I find that the #3 needle/nozzle is best for the majority of the work I do. If you're going to use the #1, the paint needs to be pretty thin...
- as mentioned, I find that the VL generally uses higher psi than my badger.
- get a color cup if you don't have one. They're a lot easier for doing small paint jobs.
- practice, practice, practice ..... and have fun.
Enjoy!
Murray
