My Alclad tips....and you can send me a certified check when done reading :)
First I wet sand the whole aircraft starting with 1800 grit, moving all the way down to 12000 grit. The reason I do this, is because it 1) polishes the surfaces to a sleek glass finish and 2) because it doesnt ruin any of the fine detailed lines.
When that is all said and done, I mix a bottle of 3 parts water, 1 part Future and apply it to the surface in 3 coats. On the 3rd coat, I polish it with Novis to get that glass like finish. I inspect the whole surface area, to make sure that there are no bumps, scratches or runs in the Future....which is very hard to do, considering how thinned out it is.
I have learned that Alclad will intensify the surface. Meaning that the shinier, and smoother the surface is, the shinier and smoother the alclad finish will be.
I apply 3-4 coats of the Alclad and let it sit for 6 days before masking it off to paint the other pannels, or to apply the delas. I don't buff it out in the end, I have added fine scrathes to the finsh.
I use between 7-10 PSI, and the distance from the model is about 2-3 inches. Maybe pull back if it is building up. I used a 2 way Badger Air Brush, and never start or end the spray on the model. Always point the brush in the air, to get the paint flow going. I have had bad hicups in the past.
For a mirror like image, I have added a top coat of 1/2 water, 1/2 Future
