Semi-gloss or satin black
Posted by Bones-coa on Monday, November 1, 2004 10:19 PM
Modelers, when I was young I came up with the bright idea of mixing 50% testors flat black with 50% testors gloss black to give me a semi-gloss black in a bottle. Has anyone else done this? I seem to recall it working but I think my standards may be a little higher now. Big Smile [:D]
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
Posted by Bones-coa on Tuesday, November 2, 2004 8:54 PM
Wow...no takers? Ok. So I assume everyone paints the parts black and then sprays them with semi-gloss clear coat?
    June 2004
Posted by clfesmire on Wednesday, November 3, 2004 6:50 AM
Actually, if you leave a bottle of flat paint sit long enough and don't agitate (stir/mix) the media in the paint that makes it flat will settle and you will get the satin finish. Conversely, if you add a media (such as talc) to glossy paint it will become flatter.
    August 2004
Posted by jdavidb on Wednesday, November 3, 2004 10:14 AM
there's the MM color labeled "Black Chrome Trim" which is satin black. That color is the center of the universe for me.
Posted by Anonymous on Wednesday, November 3, 2004 8:10 PM
I didn't see your post until now. Yes, I used to do that in the early 80s when the only Satin Black was a hard to find Humbrol Shade or one of the aircraft color line by the defunct Pactra, called either Aircraft Black or Radome Black. Otherwise, for radomes and such, I either mixed gloss and flat black, which was best, or gloss and flat clear, which was an unwanted one more fat coat of paint to hide detail, and just wasn't and isn't as satisfying, and I use that method in a pinch even now. I miss some of those old Pactra paints, especially the Anti-Glare Panel Green. It was perfect for 1950s aircraft (the real color is Medium Green Flat, but Pactra sunbleached it, which it was).
Speaking of mixing, I matched the commercial shades of RLM 66 scwarzgrau (black-gray) for cockpits and such, against the chips in the Monogram Publishing Official Painting Guide to the Luftwaffe, and I found that the commercial shades were all too light, even accounting for scale lightening. So I mixed 50-50 MM black and Gunship Gray, and guess what? A perfect match with a tiny lightening for scale, and so all that detail won't vanish in the blackness. It's also good for tires, with a dry brush of lighter tire gray on the part where the rubber meets the road.
Tom
    March 2004
Posted by bstrump on Wednesday, November 3, 2004 8:13 PM
Bones, yours is actually a good idea since you can vary the mixture to the sheen you want without having to buy the various brands versions of "satin black". There's Humbrol Coal Black, a very low lustre, Tamiya Semi-Gloss Black with much more sheen, MM Black Chrome Trim et al.
