how can i strip tamiya sprey and enamel
Posted by Anonymous on Friday, November 5, 2004 2:51 PM
I know this has perhaps been covered before but i need help
hay i've done a terrible botch up on my painting.
How can i strip both sprey and enamel off my model
    May 2003
Posted by styrene on Friday, November 5, 2004 3:48 PM
I haven't tried it personally, but I understand through this forum that Castrol Super Clean (I think that's right) works really well. Easy-Off oven cleaner also works well for paint removal, but it's best done outdoors with some gloves and protective eyewear. For both materials, you need to let them soak for awhile, then wash REALLY good to remove any excess.
One question, is there some differentiation between "sprey" and enamel? If you are talking about sprayed-on enamel, or overspray, the methods above will work for all paint types...
Gip Winecoff
Posted by Anonymous on Saturday, November 6, 2004 1:00 AM
Is the sprey the can spray of tamiya. in that case its a lacquer. You can strip lacquer by soaking it in DOT 3 brake fluid. and the brake is reusable.
Reza
