PE Painting
    August 2004
PE Painting
Posted by Tankmaster7 on Thursday, November 18, 2004 3:35 PM
I'm going to use a czech master detail set(PE) for a fw-190 in 1/72 scale. Anyway, does the PE need a coat of some sort of primer? Or will the paint adhere to it OK? I'll be using both acrylic and enamel paints for the cockpit.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    April 2004
Posted by pmm736 on Thursday, November 18, 2004 6:50 PM
I was wondering the same thing. I just got a Hasegawa braile scale Tiger I that came with an Eduard PE zimmerit set. The instructions don't say.
Posted by Anonymous on Thursday, November 18, 2004 7:06 PM
Best prime it, the metal is very smooth and does not hold paint well.
Alternatively you can immerse it in vinegar for a bit, this also roughen the PE.
    April 2004
Posted by pmm736 on Thursday, November 18, 2004 7:06 PM
Just checked the Eduard web site. In an instructional section the author says that you can prepare the parts by soaking them in vinegar for a couple of hours or lightly sanding them with 100 grit sandpaper. He goes on to say that he doesn't do this because he cleans his models before painting, though he doesn't say with what. He doesn't mention priming, nor does he say whether he uses acrylics or enamels. Don't know if that helps or not, but it sounds like a quick cleaning is all the PE needs.
    August 2003
Posted by tweety1 on Friday, November 19, 2004 10:15 AM
Roughen up the PE with a FINE grade sandpaper.
All you need is a slightly etched surface, not big gouges.
Then give it a quick wash with some Iso to remove oils etc, and your good to paint!!
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
