need overall metallic help please!!
Posted by Anonymous on Thursday, November 18, 2004 8:17 PM
I've just started airbrushing and I need advice for painting acriylic metalics.
I want to airbrush Testor MM alluminum over clear doped linen. Also, disregard my spelling. I'm only 13! Big Smile [:D]Big Smile [:D]Big Smile [:D]Any help would be much appriciated. Thanks,
Fletcher
    July 2004
Posted by tho9900 on Thursday, November 18, 2004 8:29 PM
as in the color clear doped linen? what are you airbrushing as in what kind of kit? and what do you need to know about brushng it?
enamel metallics usually cover and look better in my opinion, but the acrylic ones work... I have used them once and had to do several light coats for coverage... looked ok though... just prefer enamels myself...
----edit----
(forgive my spelling, I am only 38 Wink [;)])
    January 2004
Posted by MusicCity on Thursday, November 18, 2004 9:17 PM
When you say "MM Aluminum" are you talkling about MM Aluminum Metalizer? The MM Metalizers are laquer, not acrylic. If that's what you are talking about my advice would be to be very careful spraying it over acrylics. Let the acrylic cure thoroughly (as in 2 or 3 days), and spray the first couple of coats of metalizer very, very thin. Laquers are aggressive and can dissolve acrylics.
If you are talking about plain old metallic paint (as in silver, gold, etc.) there is no real problem in spraying them over another color.
(please disregard my spelling, I'm only 53)
    August 2004
Posted by Tankmaster7 on Friday, November 19, 2004 7:05 PM
Well, you need to make sure your model is free of any blemishes whatsoever. They will really show through a shiny metallic color. Also, MM metalizer doesn't adhere well to plastic from what i've heard... so be careful. you can disregard my spelling i suppose... my age is less that or equal to 17. that's all you're getting out of me! and that much you could see from my YG GB sig anyhow. lol.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    May 2003
Posted by qmiester on Saturday, November 20, 2004 9:04 AM
I'm assuming that you are applying this to an aircraft model. If you are, I would reccommend that you leave out the doped linen and apply the silver directly to the model. On a 1 to 1 a/c, the minimums are 3 coats of clear dope applied over the fabric followed by 3 coats of silver dope. All 6 coats are supposed to be applied with a brush and can be lightly sanded between coats. Those are the minimums, but most people apply more coats because as the more coats you apply, the smoother the finish is. The thing to note however, is that after the second coat is applied, the doped linen is no longer showing.
I don't use metalizers to represent doped surfaces as they are made to represent metal surfaces. I would recommend shooting MM Flat Aluminum on the surface topped by a semi-gloss clear. Silver doped surfaces tend to weather very rapidly to a dull finish.
On a side note, I always sand the "fabric" weave molded on the surfaces by the kit manufacturers off. The weave is so small that you wouldn't be able to see it, the only clue on a model would be the sag of the fabric. (and depending on the internal structure of the cloth covered item, there may be no sag - you'd be surprised the number of people who don't know the rudder on a P-51D is fabric covered)
Quincy
Posted by Anonymous on Saturday, November 20, 2004 3:12 PM
I just finished spraying my P-51 Tamiya chrome silver, at first I was dissapointed to see a grainy looking colour but as soon as i buffed it with a cloth it seemed to disappear and produced a nic smooth shiny silver. Tamiyas acrylic metallics are good because the can easily be cleaned and produce nice paint jobs!
Posted by Anonymous on Saturday, November 20, 2004 7:31 PM
how do you buff metalizers ? just get a cloth in there and rub ?
Posted by Anonymous on Saturday, November 20, 2004 8:32 PM
Thanks guys!,
That helps a lot. After reading your advice, I sprayed the Aluminum on the bare plastic. It looks great! Once again, thanks!
-Fletcher
