CFM for paint booth
CFM for paint booth
Posted by Anonymous on Friday, November 19, 2004 11:08 AM
I am in the procees of making my own paint booth which will be vented through my window. What cfm should I be trying to move out? I plan on making it out of a cardboard box or something like that. Any great ideas, tips, or plans for a homemade version would also be appreciated. Thanks everyone.
    May 2003
Posted by styrene on Saturday, November 20, 2004 9:50 PM
Hi,
First, DO NOT use a cardboard box as your booth. If you're going to build one, do it right. A good fire-resistant plywood or sheet metal are the best materials.
As far as CFM goes, it is predicated on your booth size. In order to maintain adequate capture, face velocities should be between 80-100 fpm. So, if your booth face size is going to be--let's say--2ft. X 2ft., then the area = 4 square feet. Multiply this by the required face velocity and you get a MINIMUM cfm of 320-400 cfm. Depending on the length of exhaust ducting, you may need to bump up your cfm by about 20% or so to ensure adequate duct transport velocities. Your exhaust ducting should be constructed of at least 4" aluminum flex duct. Stay away from plastic dryer hose. In addition exhaust ducting runs should be as short and horizontal (downward is even better) as possible, and with as few bends as you can get away with. Try to avoid right angles. With every bend and turn you add airflow resistance.
Your fan should be of the shaded pole type. A good squirrel cage fan is excellent for this type of application. The motor should not be in the direct airflow of the vapor stream. For this reason, stay away from range hoods, bathroom fans, computer fans, and the like.
I would ecourage you to do a search on spray booths in this forum. This subject has been covered fairly extensively, and the information could help you immensely. If you have any questions, please feel free to shoot me an e-mail. Other forum members will also provide a wealth of information on this thread. Good luck in your build.
Gip Winecoff
Posted by Anonymous on Tuesday, November 23, 2004 9:17 AM
Thanks Styrene your help is appreciated.
    September 2004
Posted by mm23t on Tuesday, November 23, 2004 6:02 PM
captain-insano, you could order a back issue of FSM...the December 2000 issue has an article with plans to build a spray booth.Whistling [:-^]
Medals are not "Won", they are "Earned".
Mike..
