Pre-Shading
Pre-Shading
Posted by kaimuki21 on Saturday, November 20, 2004 1:45 AM
What is the correct method to pre-shade aircraft panels? What colors do you use and what is the order to proceed in? Appreciate any help.
    March 2004
Posted by Mark Joyce on Saturday, November 20, 2004 9:21 AM
I use black for preshading, on both upper and lower sufaces. Basically, I airbrush most of the panel lines. I freehand it, meaning I don't tape off the lines. I just eyeball it and follow the line as straight as I can.
The tricky part is the overlying coats. You must mist those on gradually, otherwise you can easily apply too much paint and your preshading will disappear.
I'll add this disclaimer: A lot of people don't care for preshading, saying it is unrealistic. Personally, I use it and think, if well done, it's a very useful technique. Unfortunately, I still haven't perfected it myself!Wink [;)]
Hope this helps,
Mark
Ignorance is bliss
Posted by rjkplasticmod on Saturday, November 20, 2004 10:20 AM
Mark described the accepted method very well. Personally, I am not a fan of the technique. If you want a heavily weathered effect with a lot less hassle, I think post-shading is much more effective & easier in the long run. Just my My 2 cents [2c].
Regards, Rick
    July 2003
Posted by saltydog on Saturday, November 20, 2004 12:25 PM
i'm with rick on this one, but personal preference is key here. i've tried both methods and prefer post shading. personally, i feel that i have more control of the look i'm trying to achieve with post shading. when i did preshade, i would paint my bird light grey, then do the panel lines in a charcoal grey and then paint my colors. good luck. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    August 2004
Posted by Tankmaster7 on Saturday, November 20, 2004 12:43 PM
What's post shading? How do you guys do this?
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Saturday, November 20, 2004 3:04 PM
Post shading is usually done after painting the model, I use pastels to shade around panel lines to give a nice worn or faded effect using lighter shades of the colour!Smile [:)] you can also use your airbrush for post shading using diluted paints and spraying them on the model very lightly.
    April 2004
Posted by crockett on Saturday, November 20, 2004 4:30 PM
Kaimuki,
Here is an example of preshading. The panel lines were shot with a dark gray acryllic, then sealed with dull cote. The base coat (acryllic)was then shot between the panel lines. The finished base coat was then lightly dusted with "buff", to tone down and blend the effects.The regulator was at about 8 lbs. for both applications. This was my first try at pre-shading, and I really like doing it. I'm going to continue with this technique on future builds that warrant this look. Although I am not an expert, it seems to me that the key to success is to regulate your airflow and paint feed so as to get close to the work surface, so you don't obliterate the preshade.
Steve
    August 2003
Posted by tweety1 on Saturday, November 20, 2004 5:33 PM
Post shading is my personal preferance.
With this method you take your base colour and lighten, or darken it a fraction.
With careful application, you can acheive a very realistic effect, bringing life to an otherwise plain looking panel.
I have found that pre shading can lead to the tortoise shell effect, at least thats how it looks to me on my models.
For some reason it's one of the things that eludes me in modelling.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by kaimuki21 on Saturday, November 20, 2004 5:57 PM
Thanks everyone for the advice.
Posted by Anonymous on Monday, November 22, 2004 5:41 AM
Hi, at the moment I am trying to use both the methods.It gives a great cromatic variety.
Giulio
