thinning Dullcoat
  • From: directly above the center of the earth or known as Dixon, IL.
thinning Dullcoat
Posted by NEW MEX on Saturday, November 27, 2004 10:00 PM
can any body tell me the ratio of thinner to Dullcoat, my bottles of thinner and Dullcoat did not have the mix ratios on them. thanks for the help
    January 2003
Posted by plasticmod992 on Saturday, November 27, 2004 10:48 PM
Having used Testors Dullcote and Glosscote exclusively for my models, I have had consistantly great results with a ratio of 1:1. I set my compressor at about between 15-20 Psi. When I don't want to use Future as the Gloss and have to wait for it to cure, I airbrush the Testors Glosscote, mixing it at a ratio of 2:1, with the same compressor setting. This is because I have found that you have to build up the layers a bit. To offset this I simply add an additional eye-droppers full more (2:1) for Glosscote. Works great, and becuase they're laquers, they dry almost instantly, allowing me to move right along with weathering washes with no problems. Give it a shot!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by NEW MEX on Saturday, November 27, 2004 11:20 PM
thanks plasticmod992. the consenciss seems to be a 50/50 mix. i've been several other ratios so i'll try them all and see which one works best. thanks once again.
